fpga serial communication
hello,
i am using Crio and i am having a problem in serial communication even i flowed the exact steps from the exampls i always recive the same error which is "poly VI visa configure serial port: bad linkage to sub vi" is it a visa settup issue?? knowing that when i run NI MAX it indicates that there is a visa error under the peripheric and interfaces of my Crio.
thax in advance.
(2,723 Views)
Can you show the code? With that error I would expect one or more broken wirtes.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,691 Views)
thnak you fir your reply, i had a problem in the visa configuration seria port, but its ok now.
(2,673 Views)
