fpga unexpected error reported from new vi wizard
Yes this is correct.  Attached is a screen shot of my MAX; maybe there is something else that I am missing that could cause it.
Message 11 of 16
(860 Views)
Hi Joe,
I completed building a machine running LV SP1 with FPGA abd RT 11.0.0 but unfortunately was unable to reproduce your problem.
Would it be possible for you to post a System Information? You can get these through MAX by clicking Help>>System Information and then you can copy the contents. This will give me a better idea of the versions you have installed.
Also, when you say in a previous post that you repaired and reinstalled the system, can you describe the process used? In some cases it is possible for installations issues to remain after a reinstall if the problem relates to something in the registry. Did you also reinstall the RIO driver when you reinstalled LV, RT and FPGA and if so did you install it before or after the others?
Best Regards,
Chris
National Instruments - Tech Support
Message 12 of 16
(852 Views)
Below are the system information that you asked for.  As far as the uinstall/reinstall order.  I went to Control Panel > Programs and Features > National Instruements and did it that way.  I don't explicitly remember uninstalling/reinstalling RIO at all unless it did it automatically.  I only unstalled/reinstalled LabVIEW and the FPGA module.
Operating System(OS)                          Professional
OS Version                                   6.01.7601
OS Info                                      Service Pack 1
Processor                                    Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz / Intel64 Family 6 Model 42 Stepping 7 / GenuineIntel / 2195 MHz
Number of Processors                         8
Physical Memory                              7.95 GB of RAM
Drive C:\                                    558 GB of 698 GB free
National Instruments Software:               Version:
NI-CAN                                       2.7.3f2
CVI                                          10.0.1
CVI AddOns                                   LabWindows/CVI Shared AddOns
CVI Run-Time                                 10.0.1.434
NI-DAQmx Device Driver                       9.5.0f2
NI-DAQmx ADE Support                         9.5.0
NI-DAQmx MAX Configuration                   9.5.0
NI Script Editor                             1.3.4
NI-DMM                                       3.0.5
     DMM Soft Front Panel                    3.0.5
NI-DNET                                      1.6.6f1
NI-FGEN
     Configuration Support                   2.9
     Development Support                     2.9
     Run-Time                                2.9
     FGEN Soft Front Panel                   2.7
FieldPoint                                   6.0.10
     LabVIEW Interface                       6.0.10
NI-488.2 Software                            3.0.2
NI-IMAQ Software                             4.6.4
NI I/O Trace                                 3.0.1f0
IVI Compliance Package                       4.4
LabVIEW Run-Time 2010 SP1                    10.0.1
LabVIEW Run-Time 2010 SP1 (64-bit)           10.0.1
Measurement & Automation Explorer            5.1.0f0
NI-Motion                                    8.3.0.3000
Measurement Studio                           Visual Studio 2005 Support - See individual versions below.
     DotNET
          Common                             9.1.20.163
          Imaq                               4.60.20.49153
          Imaqdx                             3.40.20.49153
          MaxConfiguration                   8.9.20.111
          Vision.Common                      11.1.20.100
Measurement Studio                           Visual Studio 2008 Support - See individual versions below.
     DotNET
          Common                             9.1.35.163
          Common (64-bit)                    9.1.35.163
          Imaq                               4.60.35.49153
          Imaqdx                             3.40.35.49153
          MaxConfiguration                   8.9.35.111
          MaxConfiguration (64-bit)          8.9.35.111
          Vision.Common                      11.1.35.100
NI-Industrial Communications for CANopen     1.0.1
NI-Industrial Communications for DeviceNet   2.0.2
NI-OSI                                       1.1.0
     NI-OSI Explorer                         1.1.0
NI-USI                                       1.9.1.4681
NI-5690                                      1.1.0
NI-DCPower                                   1.6.3
     NI-DCPower Soft Front Panel             1.6.1
NI-HSDIO                                     1.8.1.1
NI-HWS                                       1.4.9
NI-IMAQdx                                    3.9.1
NI PXI Platform Services                     3.0.3
NI-RFSA                                      2.5
     NI-RFSA Soft Front Panel                2.5
NI-RFSG
     Configuration Support                   1.8
     Development Support                     1.8
     Run-Time                                1.8
NI-RIO                                       4.1.0
     CompactRIO                              4.1.0
     CompactRIO Module Software              4.1.0
     R Series                                4.1.0
     NI FlexRIO                              2.2.0f2
NI-Sync                                      3.3.0
NI VeriStand                                 11.1.0
NI-VNA
     Development Support                     1.2
     Run-Time                                1.2
     VNA Soft Front Panel                    1.2
NI-XNET                                      1.4.0f0
NI-PAL Software                              2.7.1
NI-SCOPE
     Configuration Support                   3.8.7
     Development Support                     3.8.7
     Run-Time                                3.8.7
     SCOPE Soft Front Panel                  3.8
NI-Serial Software                           3.8.1
LabVIEW SignalExpress                        5.0
NI-SWITCH                                    4.5.0f1
     Soft Front Panel                        4.5.0.49153
NI System Configuration                      5.1.0f0
NI-TClk                                      1.9.1
NI-VISA                                      5.1.2
     NiVisaServer.exe                        5.1.0.49152
     NIvisaic.exe                            5.1.2.49152
NI-VISA Runtime                              5.1.2
LabVIEW                                      11.0.1
     FPGA                                    11.0.0
     Real-Time                               11.0.0
LabVIEW Run-Time 2011 SP1                    11.0.1
LabVIEW Run-Time 8.2.1                       8.2.1
LabVIEW Run-Time 8.5.1                       8.5.1
LabVIEW Run-Time 8.6.1                       8.6.1
LabVIEW Run-Time 2009 SP1                    9.0.1
LabVIEW Run-Time 2009 SP1 (64-bit)           9.0.1
Message 13 of 16
(843 Views)
Hi Joe,
Based on the fact that I have replicated your system and I am not seeing the same issues I'm thinking that this is likely to be a corrupt installation issue. When you reinstall something through Programs/Features it doesn't actually perfrom a full reinstallation. There are somethings that remain untouched. Often it is necessary to uninstall the software completely and start from scratch.
Before attempting that I would suggest doing a reinstall of RIO as this is currently the only thing you haven't tried reinstalling.
Best Regards,
Chris
Message 14 of 16
(840 Views)
Reinstalling RIO did not help.  I am going to uninstall/reinstall everything and hopefully that fixes it.  If using Programs/Features doesn't completely uninstall NI software, then how do you get rid of everything?  Thanks.
Message 15 of 16
(823 Views)
I completely uninstalled and reinstalled everything NI-related on my computer and it still crashes.  I'm not sure why it doesn't work.  I got it to work on a lab computer, but this computer is where I am going to be primarily doing developmeny on.  I guess I will have to work with what I can get unless anyone has any other ideas?  Thanks.
Message 16 of 16
(815 Views)
