fpga
Of course, the code will work in the full range -10V..10V. It's really simple math.
The value will fluctuate, that's just in the nature of measurements. If you think there is an offset then you can correct for it.
Look at the DMA examples for how to transfer values to the host system.
Message 21 of 26
(675 Views)
I would just like to say that it is best to do as much calculations and processing using the raw value as possible.  This will use less gates (very important in FPGA) and be more accurate.  Once you transfer the data to the host, let the host convert into a double.  This will give you the best accuracy.
GCentral
Message 22 of 26
(670 Views)
hey i am not able to correct it for 2.50....what is the maths behind dis can you please explain it once
Message 23 of 26
(668 Views)
You shouldn't correct a value just because you expect it to be 2.5V. It's possible that the analog inputs have an offset, but that's usually below a mV for that FPGA card.
How do you know the value is actually 2.50V?
Message 24 of 26
(647 Views)
actually i measured it via multimeter ...it shows 2.5 v....
Message 25 of 26
(642 Views)
How precise is your multimeter? What's the resolution, 12bits?
If you think your reading is off by -0.01V then add 0.01V to it.
You might also want to think about averaging several readings from the FPGA analog input if you're interested in the DC value. Or use a low-pass filter.
Message 26 of 26
(636 Views)
