frequency of signal from anemometer
hello,
I 've to the output of an anemometer, an AC voltage whose frequency is related to the wind speed. unfortunately I did not get my signal frequency. I'm using the CompactRIO 9074 with NI9221 module. I see my good signal but I can not seem to extract its frequency. Have you any idea of VI? This is urgent.
Thank you.
Message 1 of 17
(3,490 Views)
Hi levla,
count zero crossings (per time unit) to calculate frequency…
What have you done until now? Where exactly do you have problems?
Message 2 of 17
(3,483 Views)
Are you trying to calculate this in the FPGA or in the RT?
If in the FPGA, you need to count the zero crossings to get the period and then invert.
If in the RT, then there is a bunch of FFT and frequency analysis VIs in the Signal Processing palette.
GCentral
Message 3 of 17
(3,472 Views)
hi  ,
I have a signal like the attachment picture. My problem is that I can not seem to extract the signal frequency. My frequency must be multiplied by a coefficient to match the speed of the wind.
I work in RT.
thank you
Message 4 of 17
(3,465 Views)
What is your timing resolution?
How do you read the signal?
What is the expected AC voltage frequency for your sensors measurement range?
Message 5 of 17
(3,460 Views)
I put a screen capture of the code as an attachment. I read my signal from the anemometer on the AI2 port NI 9221. For my range-measuring sensor, I have to measure frequencies from 0 Hz to 125 Hz. Documentation of the anemometer is attached too.
Message 6 of 17
(3,452 Views)
Hi levla,
you want to measure frequencies upto 125Hz, but you sample your data with just 10Hz (100ms loop time).
Have you ever heard of Shannon-Nyquist?
Message 7 of 17
(3,449 Views)
I forgot Shannon-Nyquist. I put a frequency of 350 Hz Sample Rate (285ms) but I still can not get my signal frequency. Is my code is right according to you? thanks
Message 8 of 17
(3,438 Views)
Hi levla,
you wired a 3ms wait for an expected 333Hz sample rate. Don't know where your numbers are coming from.
BUT:
How did you configure your scan engine? Does it work that fast?
All of your data analysis is also highly flawed. How do you expect meaningful results when you try to measure frequencies from just single samples? Those functions expect an array of samples (or a waveform) for a reason…
Message 9 of 17
(3,431 Views)
Hello ,
I work in RT and attachments you have documentation of the anemometer and my code screenshot.
thank you
Message 10 of 17
(3,426 Views)
