front panel objects in boxes
As much as this feels like a really silly question...................
What do I need to do to move a group of front panel objects, controls indicators and such into a box?
Sometimes it works like a charm, other times I can not put items in the box, they want to go "behind" the box.
Also, whan I try to move a box and it's things into a tab control, all of the objects in the box are "hidden" behind the box, what am I missing?
Michael C. Nedrow
(4,939 Views)
Accepted by mcnedrow
On the top right of your front panel toolbar is a button that has two circular arrows.  It allows you to reorder the controls.
(4,934 Views)
Are you talking about moving objects in front of a 'decoration'?
Or putting objects in a 'tab control'?
For the former, select the decoration, then on the top toolbar, click 'order', 'move to back'.
For the latter, just click and drag objects into the control
Edit: Why am I always 1 min too slow Smiley Very Happy
Message Edited by Cory K on 04-02-2009 10:37 AM
Cory K
(4,933 Views)
Michael
It probably depends on the order of the objects you are moving and the order of the Box you are moving to.
use the Reorder tool to change the order of the objects.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(4,929 Views)
Thanks to all
I guessed that it was a silly thing I was missing
Thanks Again
Michael C. Nedrow
(4,925 Views)
You can also try with Controls->Modern->Decorations->Flat Frame to make your VI looks good. or
Go with anyone layouts in Controls->Modern->Layout ..
(1,910 Views)
