function palette not exact
hi all, my function palette seems different when I opened it by left-clicking on the block diagram window. I attached a print screen below. how could I correct it. it does not seem proper and have lost functions on it.
Egemen
Message 1 of 11
(3,584 Views)
Tools -> Advanced -> Edit Palette Set
You should be able to do some changes thereSmiley Happy
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 2 of 11
(3,576 Views)
thanks for your reply but I could not fix it by this way and I really do not know how to do it. Even I appylied the "restore default settings", it turns the same scheme.
Egemen
Message 3 of 11
(3,562 Views)
Accepted by topic author newbieeng
It appears that some of your categories were set to be not visible. You can switch the palette view to "Category" and see which ones are set to be visible. This is saved in the labview.ini file with the key "PaletteHidddenFunctionlCategories".
Message 4 of 11
(3,556 Views)
thank you. this solved the problem. 🙂
Egemen
Message 5 of 11
(3,547 Views)
One more simple solution would be
  • Right click the block diagram
  • Pin the function palette
  • Click the Customize button
  • Select View this palette as>> Category Standard
You are done.
Message 6 of 11
(3,542 Views)
You are done.
I met up this problem when I click the right of the mouse. your method affects the main function palette.
Egemen
Message 7 of 11
(3,535 Views)
You are done.
Affects the main Function palette?. In which way ( I am just curious to know why this happens )
Message 8 of 11
(3,533 Views)
this way affects only the main function menu view. If you do not make all your functions visible, when you click right on the block diagram window it seems mostly empty.
Egemen
Message 9 of 11
(3,524 Views)
Yes you have to select the visible category in that. Is it coming empty even after doing this?
Message 10 of 11
(3,518 Views)
