generate and control voltage
I want to generate and control voltage (0 to 10) (V) using ni-9269. I did it easly with  alhabeeb_0-1724230249442.png. How can I do it by using alhabeeb_1-1724230311806.png
(397 Views)
Hi alhabeeb,
I did it easly with DAQAsisstent. How can I do it by using DAQmx functions?
Open the example finder and look for all those DAQmx example VIs!
Did you already read this article?
(381 Views)
Thanks, but all examples didn't mention what I need.
(368 Views)
Accepted by alhabeeb
Hi alhabeeb,
Did you examine these examples?
Which part are you interested in and what is missing in the example VIs?
(355 Views)
Thanks I got it.
(329 Views)
Don't forget that you can also convert your DAQ ASSistant to DAQmx code after you get it set up.  Right-click and you will find options to open its front panel or convert it to DAQmx.  It's a good way to transition into real DAQmx code as you're learning.
(318 Views)
Thanks for the info.
(280 Views)
