08-21-2011 12:21 PM
When I choose "Create Labview VI" in Vision assistant and go for"IMAQdx Image Aquisition", i am pompted to manually search the "IMAQdx open camera.vi","snap.vi"and "close camera.vi",which i can't find.I have installed Labview2010,IMAQdx 4.4.
thank you.
08-22-2011 03:30 AM
According to this page, NI IMAQ 4.4 is not compatible with LabVIEW 2010.
You need to get at least NI IMAQ 4.5, you should be able to get from ni.com/drivers.
Hope this helps
Epictetus
08-22-2011 07:19 AM
I had a similar problem. If you don't have a Vision Acquisition License, Labview doesn't show those VIs (even if the IMAQdx is installed).
Cheers
Angel
08-22-2011 11:56 PM
You cam download and install .exe file at http://joule.ni.com/nidu/cds/view/p/id/2625/lang/en. This should solve your problem.
Sanjoe
