help by making a ohm meter
hello every body i need help
i trying  to make a ohm meter just my calculation is not  as expected
Use a known resistor to measure the current (measure the resistor first). Use the 5 V output of the myDAQ as voltage source. Measure voltage across unknown and known resistor. Let your program calculate the unknown resistor.
 i took a 1000 ohm that i knew the second one is a 220 ohm it just doesnt work as wel i used a voltage division formule to calculate it.deddd.jpg
(803 Views)
A picture is not useful to troubleshoot. Please attach your VI.
  • We cannot tell how the express Vi is configured and what the numbers in the array mean.
  • We cannot tell what's in the dynamic data wire
  • Unless you resize the indicators to make them wider, we cannot even tell what the values are (the first could be 4,6E-99 or 4.6E+99, for example.
  • Why is your iteration indicator orange?
  • Do you know how much current your 5V source can supply?
Can you explain that sentence in a few more words? What do you mean by "doesn't work as well"? (Value slightly off? Completely wrong?). Does your math work correctly if you replace the DAQ with a simulate value?
(772 Views)
f4b5e29a-3986-4c2a-aab6-596f33b1ad8c.jpgthe system has to work that it calculate spanning 2 resistor2 what ohm value it has
R1 is 1k ohm
R2 is 220 ohm in the picture its 1k i changed it to 220
the problem is that mu output value is 0.05 not 220
(765 Views)
I cannot look at your Vi unless you "save for previous, 2020".
You have not answered most of my questions.
(746 Views)
you mean version 20.0
(740 Views)
@insignia11 wrote:
R1 is 1k ohm
the problem is that my output value is 0.05 not 220
You have your channels flipped (R2 is wired to channel 0 and is therefore the first element in the array of measurements).  By my calculations, this should give you 21.739 Ohms.  This makes me think that you measured one of your resistors wrong.  Either R1 is actually 100 Ohm or R2 is actually 22 Ohm.  So double check those with a DMM.
GCentral
(669 Views)
