hiding mouse cursors
How do i go about doing this (titled mentioned)?
I found https://decibel.ni.com/content/docs/DOC-17854 but it's not working that well for me as it stills needs a show control to control the show/hiding of cursors.
my specification is such that at a left click, it will hide by itself, once i stop (which will be a right click), the cursor will be back
Attached VI has a calling of library node (which is the showing and hiding of cursors)
Message 1 of 11
(3,893 Views)
I'm not sure what you mean by needing a show control, but you can trap mouse up and down events anywhere.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(3,886 Views)
For the show control (according to the website posted) it needs "Show" control to be 0 and return type to be less than 1 to hide, while to unhide it, you need to run the VI again  with "Show" control to be 1 and return type to be more than 0, which is not really intended for my main VI which needs to automatically do it instead of pressing the control.
So i'm looking/open to any suggestions to show/hide my cursor with the above specification.
Message 3 of 11
(3,882 Views)
That is an obnoxious VI and I don't recommend anyone to run it.  It certainly hides the mouse cursor.  That is a horrible user interfaces.
I had to blindly close out all of LabVIEW  (because the cursor is missing in all of the LabVIEW windows, not just this VI's) in order to be able clear out the cursor setting and have it back again.
I suggest you rethink whatever it is your are trying to do so there is a friendlier user interface.
Message 4 of 11
(3,873 Views)
I see.... well, i just took it from example by NI, still working on the interface for this
So do you have any suggestion for hiding the cursors? with the specification.
Message 5 of 11
(3,869 Views)
Workaround Attached.
Left Click = Hide
Right Click = Show
Message 6 of 11
(3,859 Views)
Hi, Able to downgrade to labview 2010? I'm using 2010
Message 7 of 11
(3,844 Views)
Accepted by Vincent94
Message 8 of 11
(3,842 Views)
Hahah 1 more favour, can you explain your code?
Message 9 of 11
(3,833 Views)
Basically, it's an Event Structure with While Loop.  The Mouse Down event will be activate when u Click (Left or Right Button) in ur Front Panel
If Left button pressed: "Create Cursor from File" function will create the Invisible Cursor File in Folder (1x1 Pixel size...) and "Set Cursor Function" will load that custom file.
If Right Button Pressed:  "Set Cursor Function" will load the Cursor by ID (Actually 1)... that means the normal cursor will be restored.
Sry for bad english. I'm Brazilian 😄
Message 10 of 11
(3,828 Views)
