how can I create HWS files in labview
hi
how can i create HWS files in labview?
Message 1 of 8
(5,066 Views)
What is a HWS file?
What is it used for?
You can create any file type in LabVIEW as long as you know how the file if formated.
Message 2 of 8
(5,049 Views)
You can create .hws files with the NI-HWS VIs. If you missing this palette then install the NI-HSDIO Driver.
With the NI-HSDIO Driver you get also a bunch of LabVIEW examples.
C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\instr\niHSDIO
Alternativ you can use the NI Digital Waveform Editor to create the Digital Waveforms.
For more information please check out these links:
Message 3 of 8
(5,038 Views)
Thank you so much for your informations and i would like to clearify one more question
If I want generate these programmatically what platform will be better one?
Raj kumar.S
Message 4 of 8
(5,001 Views)
You are welcome. What do you mean exactly with plattform? Do you mean PXI or PCI or which tool?
Message 5 of 8
(4,986 Views)
just am asking about C or MATLAB?
Message 6 of 8
(4,976 Views)
For the following languages is a NI-HSDIO driver support available. You need the NI-HSDIO driver for the PXI-6541 (you can find that in the NI-HSDIO readme):
Additional you can use Signal Express for NI-HSDIO (SignalExpress is a interactive software for quickly write out some signals to a NI devices, with no programming required) or you can program the board in native C.
You find the C examples after the installation of the driver here:
C:\Users\Public\Documents\National Instruments\NI-HSDIO\examples\c
With the listed Software above you can programmatically create a pattern and play the pattern on the PXI-6541. With Signal Express you can play the pattern but you cannot create programmatically the DIO pattern.
I'm not familiar with MATLAB® but it looks like that other guys have created a .hws file with this tool.
How to read National Instruments HWS waveform data file in MATLAB
hws file to matlab
General documentation to .hws can be found here:
C:\Program Files (x86)\National Instruments\NI-HWS\Docs
You can play the .hws file with all tools listed above. Alternative you can save you date in a ASCII file and play the ASCII file (presupposed the file is not too large) or you write out the programmatically created DO pattern directly to the board.
Message 7 of 8
(4,965 Views)
thanks for your suggestions
Message 8 of 8
(4,949 Views)
