how can i be notified when abort execuation button is called
@DerrickB wrote:
FYI Ctrl+. is always available whether toolbar/menu is displayed or not.
I don't believe this is true for compiled executables... I certainly hope the OP is not expecting end users to run programs from the DEV environment.
=== Engineer Ambiguously ===
Message 11 of 17
(802 Views)
If you hide just the abort, (and optionally the entire menu), CTRL+. is not available.
The VI can still be aborted, if it's used as a SubVI and it's caller is aborted, or with the abort method (if the Vi is top level).
Especially when designing a reuse library, you can't impose requirements like "don't abort your code" on users. The library should simply behave...
Message 12 of 17
(789 Views)
I tested it, even tested with modal and other settings, Ctrl+. worked with no menu or toolbar visible.
Message 13 of 17
(770 Views)
How about when it's an executable instead of running in the DEV environment.
Message 14 of 17
(767 Views)
I did not test an exe, I thought we were talking about dev stuff. It doesn't work in an exe
Message 15 of 17
(749 Views)
Yes, you have to explicitly hide the abort.
Message 16 of 17
(714 Views)
I just did as well. At least in 22Q3 dev environment:
  • Deselecting "Show toolbar when running" does not disable the keyboard shortcut.
  • Deselecting "Show Abort button" does disable the keyboard shortcut.
  • The default "Top-level application window" preset deselects both of those options, which (as you might expect) does disable the keyboard shortcut.
@Peterboshra wrote:
("note I shouldn't remove this button")
But you really should.
Message 17 of 17
(693 Views)
