how do i get a continuous waveform for a agilent u1701A?
I am trying to write a VI so that i can continuously monitor a waveform from a agilent U1071A data card, how to i get around needed a waveform array size so that i can continuously retrieve data?
any help would be appreciated,
-Lenny
(2,177 Views)
What VI's are you using to acquire the data from the device? The Agilent U1701A is not listed on ni.com as having any drivers available from NI. If the VI's you are using are from Agilent I would recommend that you contact them directly. If they are NI VI's let me know which ones you are using and I'll try to help you further.
Alex D
Systems Engineer
Academic Research
(2,150 Views)
i am using VI's provided by agilent
(2,137 Views)
The best thing for you to do is to contact them directly as they will know more about their vi's.
Alex D
Systems Engineer
Academic Research
(2,128 Views)
