how do you remove a compatexport.cpp line 38 error in LV7.1
when running TestStand - Runtime Operator Interface I keep getting compatexport.cpp line 38 error in LV7.1
Has any body got a solution
ken
(2,661 Views)
What version of TestStand are you using.  It might be worth mass compiling the vi's you are using for your user interface.. That should solve the problems.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(2,650 Views)
Thanks AdamB
The Test Stand Version is 2.0.1
The first thing I tried was the mass compiling of the vi's in the user interface dir, but it had no effect, still fails
I noted that the LV was the only user interface type that had no *.exe?
ken
(2,644 Views)
Hi Ken,
No that's not right you should have a LabVIEW *.exe.
Have you also mass compiled all of the VI's that you are using in your sequence?
Above are 2 links that show some solutions to the same problems you are having.
Have a look at these and see if they help?
In the meantime (as I don't actually have 2.0.1 installed) I'll gett looking for more info.
AdamB
(2,632 Views)
