how i can send front panel to excel with extension xlsx?
Hi
how i can send front panel  to excel with extension xlsx (For Excel 2007)?
this is my file  in attachment " and the excel sheet extension is " C:\Documents and Settings\tr1388\My Documents\New Folder\Book1.xlsx "
(4,121 Views)
there is a mistake in the old file
see the new one to help please
(4,096 Views)
I use LV8.5.1, my version doesn't allow user to select between "excel 97-2003" formal (xls) and "excel 2007"; it's just "excel". I don't know whether LV2009 allows user to do so...
Anyway, Office 2007 can open "old" xls file: xlsx will only lose retro-compatibility with old excel versions...
(4,089 Views)
Hey King Rio,
I am a little unsure what it is you are trying to accomplish. Are you looking to take an image of the front panel and paste it into excel? Are you looking to create a table of information in LabVIEW and input that into Excel? Are you trying to input data or an image from LabVIEW into an already existing Excel document?
As xdaf had mentioned, you can create .xls spreadsheet files and they will be able to open just fine (in compatibility mode) in Excel.
Perhaps a little more detail on what it is you are actually trying to accomplish would be helpful.
Hope this helps.
-Ben
WaterlooLabs
(4,063 Views)
Hi
BCHo
yes , I'm trying to take an image of the front panel to excel sheet
(4,045 Views)
Accepted by King Rio
Hey King Rio,
See below for an example of how you might go about inserting an image of your front panel into an Excel document. You may want to do a little more formatting of your image, as this example simply puts the front panel image in the upper left hand corner of the first workbook in your Excel document.
Message Edited by BCho on 01-12-2010 09:07 AM
Hope this helps.
-Ben
WaterlooLabs
(4,021 Views)
