how i conect de sensor HC-SR04 in labview interface whit arduino?
i have a proyects and i dont have idea in what about conect this sensor i labview 😕
Message 1 of 12
(4,408 Views)
Almost all of the work is in connecting the sensor to the arduino and writing arduino code. Your LabVIEW program is just going to be a simple serial read. Have you tried Google? There are several tutorials/instructions on how to physically connect and the actual arduino code. Here is just one.
p.s. To be a bit frank, I'm surprised that anyone in this day and age needs to be told about Google (or whatever your favorite search engine is).
Message 2 of 12
(4,381 Views)
Hello sacg94,
Thanks for using NI’s forums! Additional to the information that Dennis provided I send you a small example of the NI Community that uses the sensor that you just mentioned. Please note that the example uses the Arduino toolkit for LabVIEW.
Example: https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/Arduino-Uno-HC-SR04-Ultrasonic-sensor-labview...
Toolkit: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019TmpSAE&l=en-US
Hope this helps!
Luis C.
National Instruments México
Ingeniería de Aplicaciones
Luis CT
Message 3 of 12
(4,359 Views)
yeah but the LIFA whit this sensor generate a error in the arduino program 😕
Message 4 of 12
(4,345 Views)
Instead of the little smiley at the end of your post, you should have included details. What is the error number? Is it coming from the LabVIEW code or the arduino code?
Message 5 of 12
(4,337 Views)
Message 6 of 12
(4,332 Views)
its coming from the arduino code 😕
Message 7 of 12
(4,331 Views)
The image of the LabVIEW does nothing to explain the error and neither does your text. Since you say it is in the arduino code and this is a LabVIEW forum, I would suggest you post to one of the numerous arduino forums. Be sure to include your arduino code to get maximum help.
Message 8 of 12
(4,314 Views)
okay the image no work  but i need the steps for conect the sensor in my labview 😕 you can help me in this?
Message 9 of 12
(4,304 Views)
You still have not provided any information on the error you are getting.
Let's be clear on terms. When I ask about the arduino code, it means the c code you download to the arduino. It is this code that the arduino requires to recognize the sensor and to read/control it. The LabVIEW code talks to the arduino over the serial port.
Message 10 of 12
(4,290 Views)
