11-15-2014 12:13 AM
tnx a lot Zwired1
I understood that by your good guidance. I used output of scan string to invisible some tab control in diffrence situation too, by your good idea.
jusu I couldnt understand about scan string. may you explain that? it search "Tank" and used number in the string. for example:
input > Tank 5
output> 5
it delete string?
Best Regards
11-15-2014 12:50 AM
Think of it as "parsing instructions". If you know the form of the string that you want to parse (in this case it is always the word "Tank " followed by a number) you can tell it to output specific parts of the string and handle some of the datatype conversions at the same time.
Note that if the input string does not match the parsing instructions the function will throw an error so in general you should account for that and be able to handle the outputs not being populated properly. I got lazy in the VI I sent you but if you added another control called "tank 5" (and added it to the Event) the scan from string would cause an unhadled error.
