Hello there,
thanks for the tip, also I was interested in this, so I also profited from your code.
but: within LabView 8.0 I cannot select the COLOR Property of the second property node.
what I did: I tried to create your code simply new within my program, clicking the property nodes in place but I am not given the option COLOR in the pop-up menu, after the property node has change to PNL. However, simply copying your edited node and running it in LV8 still gives the desired result. It seems that in LV8 Nat.Inst is trying to prevent users from doing this, and hide this function or was I looking in the wrong menu?
Will doing so affect the stability of the code? I want to let the panel turn red, when the DAQ hardware is active and turn back grey when it's off, so a malfunction at this point could affect devices that are connected for real, that's why I'm asking.
best regards,
Ch.B.
