how to concatenate spreadsheet string to normal srting
        i try to  concatenate spreadsheet string to normal sring but it can't concatenate...here i attached my program for ur .the closed bracket  can't be concatenate.
(2,852 Views)
Accepted by GokulGKM
Hi
Your string is getting concatenated but it is getting added in the new line. If you exapnd your string indicator you can see ")" in the new line.
Eliminate the \n character and you will get the required output.
(2,827 Views)
 Hi madhanskm
I hope attached VI will work as per your requirement.
pankaj
(2,812 Views)
