how to convert bit stream to jpeg image
I am working on a project using ofdm to transmit jpeg image.
Now, I've use IMAQ change jpeg image to greyscale(u8), and make it bit stream.
The bit stream is binary 1D array. And I don't konw how to convert the bit stream to image. Can anybody give me some help? Thank you very much.
(787 Views)
There is not enough information in your post. You need to document how you do the conversion from JPEC to grayscale and them bitstream. In IMAQ or some other software? Best would be to attach your code and not as image but actual VIs. And if you are at it try to save it for previous version to at least 2020 or earlier. Many people don’t upgrade to latest version.
Rolf Kalbermatter
My Blog
(749 Views)
