how to disable vertical scroll bar bottom button
hi,
     it is possible  how to disable vertical scroll bar bottom button only not full veritcal scroll bar and i know vertical scroll bar property node this disabls hole scroll bar.
Message 1 of 10
(4,624 Views)
You could place a decoration over the button area (customize to suit your needs).
Note that you have to put the decoration on the main part of the table, then use the arrow keys to put it over the button.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 2 of 10
(4,606 Views)
hi,
       sorry i donit know what is decoration.and how can i use this pls send any image.
Message 3 of 10
(4,597 Views)
Right click on the front panel, you should see "Decorations" as an option.
Select Flat Box for example.
steve
Message 4 of 10
(4,579 Views)
Accepted by GokulGKM
Hi gokul,
you should have gone through several basic LabVIEW tutorials by now…
You will find decorations in the "decorations" FP elements palette!
Message 5 of 10
(4,577 Views)
Here's an example with a yellow decoration box over the button.
steve
Message 6 of 10
(4,562 Views)
There are several other methods of course.  You could hide that scroll bar and make one of your own, that then uses property nodes to make the table scroll.  There's extra work involved with this because you need the update to work both ways and update when the table data changes.
Or you can use an event structure, and capture the Mouse Down? and disregard it if the mouse was on the arrow, when you are at the bottom of the table.
Message 7 of 10
(4,514 Views)
If you try to customize the control, you will find there is a decoration already in the resize corner.  Just move it to the front, to cover the scrollbar.
Now you can resize the control, the decor will move with the control.
George Zou
Message 8 of 10
(4,490 Views)
also you can disable the scrolls and use two customize slid for better flexibility in use of scrolling method
Message 9 of 10
(4,465 Views)
ok thaks to all...
Message 10 of 10
(4,445 Views)
