how to edit untitle on the Write to measurement file
How to edit untitle,untitle1... on the Write to measurement file .LVM
Message 1 of 9
(3,576 Views)
Hi stevevantran,
To rename channels before writing to LVM, you can use "Set Dynamic Data Attributes"  for Dynamic data, or use "Set Waveform Attribute" for Waveform data. They are on palette "Express>>Signal Manipulation" and "Programming>>Waveform".
Hope this helps,
Mavis
Message 2 of 9
(3,565 Views)
Hi Mavis,
  I try with your advice but some how did not work. attached is the VI, Could you take a look and give me more detail.
  Thank you
Message 3 of 9
(3,545 Views)
It works perfectly fine but you strip all of that information by doing that silly Convert From Dynamic Data.
Message 4 of 9
(3,517 Views)
Hi Dennis,
   Thank you for your help input but I still not get it could you point me more detail how it work.
   Thank you
Message 5 of 9
(3,506 Views)
Accepted by stevevantran
REMOVE the Convert From Dynamic Data.
Message Edited by Dennis Knutson on 04-24-2010 11:37 AM
Message 6 of 9
(3,497 Views)
Thank you.
Message 7 of 9
(3,477 Views)
Hi Dennis,
  Do you know how to set for the  mutisignal name?, the file name are : Untitle1, Untitle2 and I would like to change to Freq1, Freq2....
  Thank you
Message 8 of 9
(3,404 Views)
You would do it the same way. You would have to use the split signals. Or, skip the Express VI and write your own header and data with something like the Write to Spreadsheet File. I don't see any reason to use express VIs and dynamic data unless you using them from start to finish.
Message 9 of 9
(3,400 Views)
