how to export graph data to excel
    Actually i want to export graph data to excel. i can do this using Graph->Right Click->Export->Export data to Excel. But i'm not able to see the whole data. it is only giving instance data. so plz let me now how can i see whole data.
Message 1 of 14
(8,934 Views)
The RCM methods operate on the selected visable data.  either change the scale to include all data or change the scale programatically.
"Should be" isn't "Is" -Jay
Message 2 of 14
(8,919 Views)
This should export all data which is currently displayed in the graph. It isn't meant for logging purposes, but for taking this "snapshot" as raw data for later analysis.
If you have an issue that the excel sheet is not containing all the data you see in the graph when performing the export, please share an example VI incl. a description on how to reproduce the issue.
If the issue is (as i suspect) that you cannot log data with that for an extended period of time, you should open the example finder and search for "Streaming".
Norbert
EDIT: Added the underlined word "currently" to improve correctness (as Jeff pointed out).
Norbert
Expert: Geometry
Message 3 of 14
(8,917 Views)
Please find the attached VI. I want to export the voltage graph data to Excel. When i stop my Program and try to export. it is exporting only the visible graph not whole. so suggest how to solve this.
Message 4 of 14
(8,907 Views)
Thanks for contacting us. When you right click on the chart/graph and export the data to an excel file, it only exports the data currently visible on the graph/chart. In order to get the whole data you can try logging it to a file directly. You can use 'Write to Measurement File.vi' for generating the file programmatically in the Excel File format (available only in Labview 2013). You can also use 'Write to Spreadsheet File.vi' which will create a .csv file for your data which you can open with Excel. You can also use other low level File I/Os VI for your purpose.
You can go through the following link for further information: http://www.ni.com/newsletter/51339/en/
I hope this helps you.
Message 5 of 14
(8,789 Views)
I would like to have a Boolean on my vi that does exactly the same thing as right clicking the graph and selecting "Export Data To Excel".  Is there no function or property that can be used to programmatically call the same function as right clicking the graph and selecting export?
Message 6 of 14
(4,427 Views)
Why not just write the same data your are graphing to a file as you graph it?
BTW: It's just numbers, the file does not have to be anything fancier than a plain text file for Excel to open it.
=== Engineer Ambiguously ===
Message 7 of 14
(4,425 Views)
You can use an Invoke node for the graph and call Export Plot to Excel (or one of the other options).
Message 8 of 14
(4,395 Views)
Yes, if you're wanting to write all of your data to a file then write all of your data to a file, and a plain text file (delimited) will work great with Excel.
Message 9 of 14
(4,367 Views)
Thanks pauldavey. That is exactly what I was looking for.
Message 10 of 14
(4,354 Views)
