how to get a decimal number of length more than 1 byte from three componnent decimal numbers
so I have to remove array subset function and directly give the array output to the type cast.is it right . I done that also. but it not working like what is expected.here I'am attaching the VI .please help
Message 11 of 35
(1,089 Views)
Did you read Gerd's message #5 where he told you to prepend a zero to the front of the array?
Message 12 of 35
(1,087 Views)
Hi perumpadapu,
did you carefully study the snippet shown in message #5? Did you read my comment for that snippet?
Did you read message #9 by Yamaeda? There also the solution is given...
Did you read message #10 where I asked you: Do you read our answers at all?
Doh...
Edit: And now message #12 also provides the solution. So by now you got 4 times the same solution for your question, but you aren't able to read it...
Message 13 of 35
(1,086 Views)
u for your reply but i'am not able to understand the answer can you send me a snippet of the answer you indicated. please kindly help me.
ok
Message 14 of 35
(1,034 Views)
Hi perumpadapu,
the snippet was already given in message #5 as also noted before!
Message 15 of 35
(1,030 Views)
but in my program its not from a array constant its from a for, s how can I modify my programn please reply
Message 16 of 35
(1,020 Views)
Have you showed us your program?  It is "from a for "  what?
With what you've been shown so far, you really should be able to figure this out.  If you can't, then I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
to learn how to manipulate arrays.
Message 17 of 35
(1,014 Views)
its a for loop  which can send commands one by one .how can I select the replies of index 2-4 and get the stepcounts. Can you please help me. I need a help to make a array of results from a for please kindly help.
Message 18 of 35
(1,010 Views)
I think you need an array subset, maybe?
Spoiler
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 19 of 35
(1,000 Views)
so can you send a snippet such that i can know how to take a value from a set of replies coming from a for loop
Message 20 of 35
(997 Views)
