04-03-2017 04:13 AM
I use the UTF toolkit from NI to perform unit tests. I need to retrieve the comment field in ASCII report generate at the end of the test. Is it possible to retrieve this field in an ASCII format report ?
Please see Attachment
04-06-2017 03:06 AM
Hello AMlgm,
i also not found a solution for this feature request. This is the reason for this post:
Unit Test Framework get Test Case Comment in Report or programmatically access to it
please feel free to add some comments.
04-06-2017 03:16 AM
Hi Alexander,
I didn't see the post. I think that is not possible at this time. It's unfortunate.
Thank you.
Best regards
Arnaud
