how to move window behind ?
I have a reentrant vi whose front panel have some fileds need to enter. When I call this reentrant vi 3 times, Labview will open 3 windows, say 1,2,3. Window 1 in most behind, window 2 in the middle and window 3 on the top (most front), same order as the time which vi was called. But I need the opposite way which means windows 3 in most behind, window 2  in the middle and window 1 on the top.
I tried different approach but not work.
1. if I made the vi modal, windows open as 1, 2,3 from behind to top, and have to close them in order of 3,2,1 because everyone is modal, last opened 3 is on the top.
2.if I made the vi floating (hide when Labview is not active) or defult, windows open as 1, 2,3 from behind to top, but I can move/select/close at will, not have to be 3,2,1 like above. It is still not wnat I want.
3. Set the property node "isFrontmost" to false (see attached) still open window 1,2,3, 3 is on the top since it is the last call.
I need a method to move the window to the behind when open the front panel, so 1st call open window 1, 2nd call open window 2 but move it behind window 1,3rd call open window 3 but move it to most behind, so the order of the 3 windows from back to front is 3,2,1.
Any suggestion will be great appreciated !
(3,523 Views)
Reverse the list opening the windows.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,495 Views)
That is the easiest way I figured too, and it is working for my case here.
Just wandor if there is a way to move window back since write FALSE to "IsFrontmost" can not move the front panel to the back.
Thank you !
(3,462 Views)
I remember there being a VI in this package that sets the Z-order of a window using a Windows API call.
http://www.ni.com/example/29935/en/
(3,457 Views)
You can call vi method Front panel -> Open, it will put it on top.
(3,440 Views)
Thank you !
The easiest ways are often the best. 😉
/Y
Qestit Systems
(3,403 Views)
