08-02-2010 06:49 PM
Hi
I need to output a finite length of the digital pulse which will start on demand at the negative slope of the imported (or exported) clock.
I am trying to get the clock exported or imported, but in no case I can trigger outputting the signal on the negative slope.
What is the trick?
thanks
Pawel
08-02-2010 06:56 PM
Which device are you using to generate your digital signal. What is the clock source? Can you attach your vi? Normally, there is a DAQ function to configure the trigger where you choose the trigger source and the trigger slope (rising or falling), which would be falling for a negative slope.
08-02-2010 06:58 PM
Hi
That's it.
Pawel
