07-27-2010 11:03 AM
There is no such thing as a 'Run Button'. You can set the VI properties so that the VI will automatically run when opened but that will not fix your basic problem. You don't have a while loop around your code and I suspect you are using the run continuous button. DON'T. After you have gone through the tutorial, look at using an Event Structure. You would have a value change event for each of your waveform select Booleans, a value change event for your print button, and a value change event for a stop button.
07-27-2010 11:09 AM
Thanks so much. i should go through the tutorial first.
05-30-2011 03:31 AM
I am using the same structure, but in this way I can save only a part of data read. what can be the problem?
05-31-2011 09:49 PM
Are you doing some sort of continuous data read? Where is this data coming from? If you find you're only getting the values of the most recently read data, then it's likely you're not properly using shift registers to store your data between iterations of your loop. It might be useful to see your code to see where you're going wrong.
06-02-2011 10:46 AM
these is my code. Thanks for your interests and help
becide
06-03-2011 05:25 PM
Hey becidea,
What data are you missing in your output files?
