how to set the start and end point when i use integral in labview
Using DAQ, I can integrate multiplication of two signals(ex) voltage signal * current signal)
But I want to set start and end point to integral so that I could target specific time interval.
Of course, I can know integral value between two points by seeing graph which show integrated signal
But I want to make a table of integral value between two points as two signals change.
My reference picture is one of my example.
Please let me know how to deal with it. Thank you!
(3,267 Views)
Try using Array Subset to get an array containing only the samples you want.
GCentral
(3,232 Views)
But My signal has x - axis of time and y - axis of amplitude of signal.
When I extract initial array from graph, I can just get amplitude value, not time.
Given this situation, using array subset, then how can i extract specific value of specific time?
Can I get amplitude value with time value together, not just amplitude value?
(3,220 Views)
For example, I want to get integral value of amplitude of signal between 0.02ms and 0.04ms.
(3,217 Views)
You should know or be able to extract the delta between each sample, then it's easy enough. 🙂 If you e.g. sample at 1kHz getting 0.02 to 0.04secs is 0.02*1000 through 0.04*1000 ==> sample 20 through 40.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,195 Views)
