how to shift elements in an array up or down without changing its size?
Yes, the "in place element version" is incorrect for left and right. My code agrees with the original.
For testing, it is also important to stay away from square arrays. Here's an improved version that makes the results more clear.
Message 31 of 41
(1,466 Views)
... and here's a faster "down version".
Message 32 of 41
(1,463 Views)
It kinda makes it hard to get realistic benchmark figures if the code isn't correct.
The whole exercise becomes moot?
Br,
/Roger
Message 33 of 41
(1,461 Views)
@User002 wrote:
It kinda makes it hard to get realistic benchmark figures if the code isn't correct. The whole exercise becomes moot?
Well, it is not my code! 😄
Since it is not a contender anyway it does not really matter. The code looked a bit fishy but I assumed that whoever wrote it actually tested it on the original LED system.
Message 34 of 41
(1,457 Views)
Actually, somebody copied the code wrong. You need to set the split dimension of the IPE correctly.
The first original was correct.
Here is the corrected version.
Message 35 of 41
(1,455 Views)
Ahh, I see.
I got into my mental test-mode again. Well. *cough* Smiley Embarassed
Anyway what a POS benchmark code, it didn't even work correctly. Smiley Frustrated
Br,
/Roger
Message 36 of 41
(1,453 Views)
Nah you forgot the shift registers "to see the action scroll by". Smiley LOL
Br,
/Roger
Message 37 of 41
(1,452 Views)
Todays lession: Do computations/operations in contigous memory for best performance.
Multicore machines can speed up operations on huge arrays.
Nothing new under the sun.
Br,
/Roger
Message 38 of 41
(1,438 Views)
Hi Roger,
It seems that you made something wrong by copying the code, as the one I posted here for tests and later modified here by Altenbach appears to work correctly for all modes and rotations 😉
Thanx for the faster Up and Down For Loop versions... but it isn't clear for me why they are faster !
HL
Message 39 of 41
(1,416 Views)
@Herlag wrote:
Hi Roger,
HL
Probably something odd happened on copying the VI from Internet or inside my head. I'm biased here, you decide. Smiley LOL
Yes, the second version operates in contigous memory. It operates on rows and not on rotating the columns.
A 2D array is stored as a number of sequential contigous 1d arrays in RAM which is partitioned by the row.
The double array datatype merely acts as a conventient "interface" for the programmer to this memory.
For each operation in the new version only contigous blocks (one entire row or 1d array) of data need to be accessed/allocated/reallocated, while on the previous column based version all 2000 "1d arrays" had to be accessed on (one element from each row).
Naturally a huge array like that will not fit into the cache, so the processor will have a lot of cache misses and performance suffers as it is column-hopping all over memory. Try do the same benchmarking but this time on a small array, thats fits in the cache. The performance difference will perhaps be close to zero.
http://zone.ni.com/reference/en-XX/help/371361G-01/lvconcepts/how_labview_stores_data_in_memory/
Not sure if I made it any more clear?
Br,
/Roger
Message 40 of 41
(1,404 Views)
