how to use single element as both control as well as indicator in labview
Hi All,
I need to use single element for both control and as an indicator.
I need not want to use its value property os shift register.
Message 1 of 15
(4,083 Views)
Hi pmg,
            I think this thread will be helpful to you.
           http://forums.ni.com/t5/LabVIEW/Using-a-control-as-both-an-indicator-and-control/td-p/1113158
Thanks as kudos only:)
Message 2 of 15
(4,076 Views)
You need to use a control since you said you want to use a control.
If you want to update what is displayed in the control programmatically, you don't have to use a value property node.  You can write to a local variable of that control.
Message 3 of 15
(4,074 Views)
If we use local variable or value of property node then i can't use it as a sub vi. This is the problem i am facing 😞
Message 4 of 15
(4,071 Views)
You never mentioned anything about a subVI in your original post.  That is why it is important to give some detail on what you are actually trying to do.
You can use a property node in a subVI.  You can pass a reference of the control that you want to manipulate to the subVI.  Then wire that reference to a value property node inside the subVI.  Now the subVI can change the value of the control in the main VI.
Message 5 of 15
(4,067 Views)
 Find the attachment code, you may get some idea as what i am trying to do. But if i am using value of this number i am unable to use this VI as sub VI for any other VI's
Message 6 of 15
(4,065 Views)
If you don't mind can you show the code of how to use reference and propety node in main VI's and sub Vi as you mentioned please.
Message 7 of 15
(4,063 Views)
Your code still doesn't explain your actual problem. If you want to perfor any calculation inside a sub vi do as same and create and indicator instead of using the value property node and the create a sub vi with the control and indicatior terminals and then use it in your main vi.
Message 8 of 15
(4,058 Views)
Your attached VI really doesn't show what you say you are trying to do.
Searching the forums for subVI and reference finds numerous message threads on what you are trying to do.  Here http://forums.ni.com/t5/LabVIEW/Control-Slide-in-subvi-by-reference/m-p/1420526 is one that I think is a pretty good example.
Message 9 of 15
(4,054 Views)
Attached vi will give you more Idea to resolve your problem.
you can try this way also.
Prabhakant Patil
Message 10 of 15
(4,032 Views)
