how to use variable between different loops
I have two inner while loops and I want too take an output variable from the first inner loop to another loop.
For example,  in the attached file if I want to take the value of x and use it in other loop to obtain value of y.
Please, any suggestions to solve this problem.
(966 Views)
Accepted by topic author Omda2022
Hi Omda,
Your problem description is not that good…
Your VI does exactly what you asked for: output a value from an inner loop and use that value in another loop!
Do you want to run both loops in parallel? Then you should "OBEY DATAFLOW!": right now you enforce the execution order by DATAFLOW.
There are techniques to exchange data between loops, like notifiers, queues, channel wires, local/global/shared variables, network communication, … (Not all of them are suitable for all purposes in the same way.)
General recommendation: You should learn to better describe your problem instead of focusing on just one (maybe broken) way to solve that problem.
(963 Views)
Great Thanks, Mr.  for your corporation.
To solve the problem I used the "Communicating Data between Parallel Sections of Code Using Channel Wires" technique.
I will describe my problem better next time 🙂
(938 Views)
