05-27-2023 11:26 AM - edited 05-28-2023 09:29 AM
Rayleigh Light scattering depends strongly on wavelength, that's why infrared photography can see through atmospheric haze (smoke, fog, dust, etc.) and why the sky is blue, right?.
The same also partially applies to the red channel of a color picture, of course. It will be less sensitive to scattered light compared to the G and B.
(Back in the days of B&W photography, we would use a red filter to make landscapes more detailed in the presence of haze while increasing contrast, e.g. make the sky dark (example).
So to turn a RGB picture into a simulated red filter greyscale picture, just extract the red channel and copy it into the G and B channels. (It will be greyscale since R=G=B).
This is a trivial problem and can be done in plain LabVIEW with code the size of a postage stamp. No need for any vision toolkits.
Once you start a new thread, also attach a typical picture.
05-27-2023 12:20 PM - edited 05-27-2023 09:02 PM
@altenbach wrote:
This is a trivial problem and can be done in plain LabVIEW with code the size of a postage stamp. No need for any vision toolkits..
I wasn't kidding!
05-27-2023 02:57 PM
Once again, Christian, you revealed why you are the Champion Knight! I never thought that the "hijacker" was talking about a color photograph that she/he wanted to "filter" (as in Photography). Sign. Maybe if we get a response in a New Topic, we'll get a better description (with, as we both noted, a "sample Image") ...
05-28-2023 02:37 PM
