01-08-2018 03:47 AM
Hello ! i am sending serial data to my labview application from hyper terminal at baud rate of 9600 bps , i am displaying that data after concatenation at a string indicator but when i send the same character consecutively then i am not getting proper representation at the receiving side.
the screenshot of the problem is posted below.
01-08-2018 06:52 AM
What other settings are you using on the serial ports? It kind of looks like a number of stop bits difference. Are you getting any errors? Can you share your code?
01-12-2018 03:51 AM
The problem has been solved. It was actually the connection problem from hyper terminal that was causing the issue.
