infinit pga timed loop
How can I make an infinit timed loop?
My program stops when i=2^32 is reached, replacing the loop with a sequence loop gives an error.
Thanks for the help
(2,501 Views)
Dear Kim,
Please note that the I terminal stops counting when reaching i=2^32, you loop will go on. So if you are using another way of counting and not the iteration, your program will continue. You can use a simple increment function and a shift register to arrange this. I hope this will help you further,
Have a great weekend!
Martijn S
Applications Engineer
NI Netherlands
(2,481 Views)
Thanks, my colleague already provided me with the right information!!
Have a nice weekend...
regards
(2,478 Views)
You can do the same (using a shift register) in a single cycled timed loop.
Make the constant at the beginning a U64. This timer will also run out
eventually (in 14600 years, at 40 MHz), but you won't see that happen.
Wiebe.
(2,472 Views)
