inserts controls into an 2D array object?
Is there an object in Labview 2012, similar to a multicolumn listbox or table, that will allow you to insert controls such as textbox, button, etc in individual cells?  Im trying to organize and maintain a lot of user configuration parameters for a long channel list.  Each channel will have the same settings ... label, enabled/disabled, path browser, etc ...
I havent found anything like this so looking for a quick fix or ideas on a way to approach handling this.
(3,019 Views)
I normally do this with a cluster inside of an array.
GCentral
(3,012 Views)
You might be able to use this.  It's an xcontrolm tha implements a table that can have different drop-down lists for each column.
(2,975 Views)
