invalid tdms file reference
Where do I need to place these shift registers? Isn't only possible on a while loop?
Is it possible to give me an example how I need to adapt my program?
Thx again for the lots of help!!
Message 11 of 14
(1,001 Views)
Hi Peira,
Yes, the shift register can only be add to while/for loop.
The 2nd step means changing shift register to tunnel, or pass a correct TDMS file path to the right shift register no matter from which frame in the case.
Message 12 of 14
(997 Views)
When I change the tunnel into shift register, nothing changes when I switch my datalog OFF/ON...
Message 13 of 14
(994 Views)
I made an event case and put in a shift register.
When my program runs I can switch to datalog, but is doesn't log and I got a delay on my stop button.
Message 14 of 14
(977 Views)
