labview 2016 64 bit
hi all
Please help me.........
Recently, i have set up labview 2016 (64 bit) on my laptop running window 10. At first, labview runs normally. After that, I set up NIDAQ1600f0. But this time, i cannot run labview. It just appears about 5 second and break down. Although I have updated all available update, it still crashes all the time. Please forgive my poor English. Thank you very much!
(2,722 Views)
Accepted by phongtram
1. With LV2016 you can run the latest DAQmx, so i'd try to install DAQmx17.1.1.
2. If that doesn't help, it might be LV 64-bit, which so far has been less supported than the 32 bit version. You could try to install the 32-bit version (and then install DAQmx, as you always need to install it afterwards).
Or optimize and go for #2 directly to save 1 install of daqmx, you can have multiple LV versions installed.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,700 Views)
I know everyone thinks they NEED the 64 bit version of everything, but unless your program needs to access more than 3.2(?) gigabytes of RAM you don't need the 64 bit LabVIEW.
=== Engineer Ambiguously ===
(2,669 Views)
Wow It worked.thanks alot for your help. 32 bit versios is what i need.
(2,650 Views)
