labview floating point and decimal differentiation
Hi, Can i know what modification can I make to let the display differentiate between floating point and decimal. For example, when I input 2+2. I would like the output of 4 instead of 4.000. And when the input is 2.2 + 2.2, how to get the output of 4.4 instead of 4.4000. And also would like to have keep 4 decimal for trigonometry function.
Message 1 of 35
(2,142 Views)
Hi tan,
set the display format of your indicator to "hide trailing zeros"…
Spoiler
Something like %#.4g would help…
Message 2 of 35
(2,140 Views)
But the indicator in the VI is string type. There is no option to set hiding trailing zero for that string indicator.
Message 3 of 35
(2,092 Views)
Accepted by tan99323
Hi tan,
In this case you are doing the NumToString conversion before displaying the result in an indicator.
Use FormatIntoString with the format string I mentioned in the other message…
(Now it would help to provide your VIs for older LabVIEW versions like my LV2017.)
Message 4 of 35
(2,079 Views)
In case to enable insert numpad input while the VI is running, what modification can I make ? So user can input date from numpad instead of press those boolean button.
Message 5 of 35
(2,013 Views)
Hi tan,
You need to catch those keypress events…
(Btw. you should use the ValueChange instead of MouseDown events.)
Message 6 of 35
(2,004 Views)
I have tried to change the event for 0-9 to value change , but still unable to input from keypad. Which element should i add to the VI ?
Message 7 of 35
(1,999 Views)
Hi tan,
you need to look for keypress events...
Message 8 of 35
(1,988 Views)
So, I need to duplicate the 0-9 mousedown event and change to key down on the new duplicated event ?
Message 9 of 35
(1,985 Views)
Hi tan,
no need to duplicate anything.
Just catch keydown events of your VI…
Message 10 of 35
(1,975 Views)
