10-12-2015 04:43 AM
Hi everyone ,
i am working with a pickering 40-575 matrix and labview . M y problem is that the labview programm is able to read the pickering card and works properly on windows cp . But when i chaged to windows 7 , the labview programm couldnt read/ communicate with the Pickering card .
( on the Pickering card are 3 resistance , and the labview prog. is supposed to show the graph tension / voltage )
Any help is welcome ,
Thanks !
habib
10-12-2015 06:34 AM
What error message are you getting?
Sounds to me like a driver/configuration issue - how do you communicate with the pickering card? If it's via serial/RS-232, you will need to install the NI VISA drivers and select the appropriate serial (COM) port for communications.
10-12-2015 06:53 AM
It definately sounds like a driver issue. Which driver are you using? There are 3 choices with the 40 series cards.
I would recommend you take your questions to Pickering.
10-12-2015 08:36 AM
'' Overflow MΩ'' is the message that i get from Keithley when the relay is connected . NI MAX is allready installed on the computer and it schows that the pickering card 40-575 is normally connected .
10-12-2015 08:55 AM
Which driver are you using for your code? If you are using the IVI driver, you have more to set up.
10-12-2015 09:08 AM
The problem is that the labview programm does not find the relay card when Keithley is on. and i get this message error on keithley's Display : "Overflow MΩ''
However ,When Keithley is off the prog. does find the relay card.
This problem didnt occur when the prog was runnig on Windows Xp .
What do you mean which driver for my code ? the prog just had been with labview programmed .
04-26-2016 06:44 AM
hi !
I am using the pickering driver . What are the set up i have to do when i am using IVI driver ?
Regards .
04-28-2016 02:45 AM
Rectification :The communication with pickering card happens through visa and driect IO .
