labview number classification
Hi I'm looking for a fast way for labview to classify numbers by class according to specified ranges. Using the number comparison tools just take me to a huge vi, which is hard to handle.
(3,318 Views)
What do you mean by a "class" of numbers?  Provide an example of what you are trying to do.
If you mean you are trying to determine if a particular number is within some predefined ranges, then the In Range and Coerce function could help.
(3,315 Views)
Thank you for answering. Precisely, I need to determine if a particular number is within some predefined ranges, and according to that, it belongs to a class.
For example
Range A: 1-1.5     -> Class A number
Range B: 1.5-2.3  -> Class B number
Range C: 2.3-3.1  -> Class C number
I used the in range function but I need to do this for 64 numbers, and at least 20 ranges, so its a lot of In Ranges for each number, connected to the max and min values. Also, now the numbers can depend on more than one range, so it gets very hard to handle. Just wanted to know if there's another more efficient way to classify them.
(3,304 Views)
Accepted by steinhoff
In Range & Coerce, like most Numeric functions is polymorphic, meaning that its inpus will accept arrays as well as scalars.  When the inputs are arrays the outputs are also arrays.  If the arrays are different lengths, the shorter array determines the length of the output arrays.
Then scan through the boolean array (Coerced?) to find the class.
Lynn
(3,297 Views)
Wow didn't thought it that way, I missed to arrange everything with arrays, thank you very much!
(3,292 Views)
Hi steinhoff,
you can also utilize Threshold1DArray for this matter...
You define the input array for that function to contain the start of each range. Then you use a FOR loop to scan all your numbers for their range:
Btw. in your example given in msg #3 you should note what happens for "1.5"! Is it belonging to range A or B?
(3,288 Views)
