labview nxg 2.1runtime install error(MD5check error)
(2,904 Views)
Can you enable the MSI and cURL logs as is shown in this KB, and then try and re-run the installation? Once you've done that, can you send me the Package Manager Logs directory (%localAppData%\National Instruments\NI Package Manager\Logs)? Feel free to direct message with those logs if that would work better for you.
Brandon Grey
Certified LabVIEW Architect
(2,868 Views)
Accepted by Magicore
I have followed the steps,There is logs in the attachment。
(2,858 Views)
