12-01-2011 09:28 AM
Hi
I want to list the files and folders inside a zip.
I read one post that suggested extracting everthing to a temp folder and then cleaning. This is very slow and I only need two small files.
I have also been searching for a suitable dos command.
Anybody with any ideas on this?
Sean
12-01-2011 09:37 AM
12-01-2011 10:12 AM
Thanks Gerd,
I wanted to avoid having to deploy more tools for installation. There's PKZIP for DOS and ZIP for cygwin.
Anyway, there is a simpler solution. Use labVIEW's unzip vi and select preview.
S
03-08-2016 01:48 PM
It can be done with .net
03-08-2016 02:17 PM
@paul_cardinale wrote:It can be done with .net
While we are resurrecting old threads, I use 7zip. I have not tested the command line with the latest update, but it is fast and quite simple.
