05-03-2023 11:00 AM - edited 05-03-2023 11:02 AM
Hello everyone,
I installed Labview 2010 on a new PC (I had to get rid of the old one). Then I tried to open a vi which I developed exactly with that version of Labview (the only one I have). Unfortunately, I got the following error:
"An error occurred loading vi: Labview load error code 9: vi version (19.0) is newer than Labview version (10.0)"
How is this possible? and how can I work around it?
05-03-2023 11:06 AM
@DavideB wrote:
Hello everyone,
Error seems like your file is stored in 2019, are you sure your old files are saved in 2010.
if needed you can use Version Conversion - NI Community. for version conversion.
