Hello!
I write VI in PDA 8.0.1 that is working fine. But then I upgraded it in PDA 8.20 and it didn't work anymore. While building it i get this error "state missing VI or C file".
Then I lost a lot of time with debugging and found out that locale variable (of cluster with check boxes) is not working, so I replace it with property node:value which is working (just to mention, "value property" is not supported in 8.0.1 so you have to use locale variable but now in 8.20 some locale variables does not work and you have to use property nodes?!?).
Is meybe somewhere a list of bugs in 8.20 and list of corrected bugs from 8.0.1 like "unbundle by name" and so on..., because it takes a lots of time to debug it.
Thank you very much,
Andrej
