modal parameter estimation
i need to use the following VI for damping ratio estimation of experimental modal analysis:
Modal Analysis  - Modal Parameter Identificator
I have FRF magnitude anb phase but i don't know how to create a          .dat file compatible with the VI
(3,367 Views)
Hello aopazove,
It's not entirely clear to me what VI do you refer. Are you referring to these VI's?:
Modal Parameter Extraction LabVIEW VIs:
http://www.ni.com/example/31121/en/
Or are you using the LabVIEW System Identification Toolkit VI's?
I remain on the lookout for your comments, best regards.
David P.
Applications Engineer
www.ni.com/soporte
(3,331 Views)
Hello aopazove,
David P.
www.ni.com/soporte
(3,331 Views)
I'm referring about the first one. Modal Parameter Extraction LabVIEW VIs.
Specifically i'm trying to use the VI that is located in the _Examples folder : Modal  Parameter Identification
Best Regards
Alexander Opazo Vega
Civil Engineer
Assistant Professor
Universidad del Bio Bio
Chile
(3,313 Views)
Do you already added the VI´s to the functions palette?
David P.
www.ni.com/soporte
(3,300 Views)
Yes, I added the VI's in the function palette.
I would like to use the example " DEMO Modal parameter identification" with other FRF data
What's the format of the FRF data?
I
(3,249 Views)
