mouse click event
Hallo,
I would like to generate a mouse click for every 1 min.
my application is, i need to press a take snapshot button every one min. i tries searching in the web for the particular VI, but im not successful. Please help me on this regard.
Parthiban
Message 1 of 13
(2,622 Views)
Accepted by topic author parthi1987
Message 2 of 13
(2,608 Views)
Thank you very much.. and it works fine.
Message 3 of 13
(2,565 Views)
Hi Paul,
I wanted to ask if you might know how to programmatically generate a mouse event, like a left button down, at specific coordinates on the screen without physically moving the mouse. Alternatively, do you happen to know a method for generating a left button down event directly on a control on the front panel in LabVIEW?
Thanks in advance,
Max
Message 4 of 13
(154 Views)
What's your purpose for the event?
What kind of control?  If the control is a button, you can use property node to generate a Boolean value change event.
George Zou
Message 5 of 13
(145 Views)
Thanks, but I need to generate a mouse down event on a string control. Doing KeyFocus doesn't help me.
Message 6 of 13
(144 Views)
So your purpose is make the strong control ready for keyboard input/paste?
KeyFocus should work.
If you show us your code, we can debug it for you.
George Zou
Message 7 of 13
(137 Views)
Simple code. I have to use moues down event.
Is there a way I can make this functionality happen?
Message 8 of 13
(125 Views)
I don't know why you choose move down event of the string control to initialize your code.
It might make your life a little easier if you go with the usual way.
if you only need initial once, add a sequence structure outside the loop.  Add your initial code in a frame before the loop.
George Zou
Message 9 of 13
(114 Views)
I would like to know how to click on a certain location on the screen without moving the mouse.
This is the main functionality. Everything else doesn't matter to me.
Message 10 of 13
(107 Views)
