multicase structure
Hi ,
i'm programming a sequence of switch,
i want to set a table of 16 possible position coded in 4 bits, to be able to commande a card motor.
i'm thinking to connect these positions to some kind of case structure but it does not work?
can i use other possible loop.
SA
Message 1 of 12
(3,484 Views)
For me this looks like You would like to make a truth table with 16 possible states.
For this using the Case Structure should work, since You can wire an U8 (8 bits, but You will use only the 4 lowest bits) value and select the case (position).
You wrote that it does not work for You.
What's the issue? Could You post a code snippet?
CLA, CLED
Message 2 of 12
(3,481 Views)
 yes it is the case, i had tryed the code attached.
 the idea is to make a table of boolean values, an depending  on the selected value execute the sequence inside the structure
SA
Message 3 of 12
(3,462 Views)
Hi SASA,
you cannot wire an array to a case structure selector. You need to index the selected entry before!
Message 4 of 12
(3,458 Views)
Instead of the case structure, just make an 2D array constant to work as your lookup table.  Then you just need to use Index Array to get the value you want.  It will be a little more efficient.
And you need to use the Boolean Array To Number function to convert your array of swithes into a number that you can use to index the right 4 bits from.
GCentral
Message 5 of 12
(3,438 Views)
SA
Just insert a Bool array to number and it'll be changed to a 0-15 number, working with the case structure.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 12
(3,421 Views)
If you do this I highly recommend showing the radix on the case structure and set it to binary.  This way you can see that case 0b100 is for when the third item in your array is true and the first and the reset are false.  In my opinion this is easier to read than having decimal 8.
Message 7 of 12
(3,388 Views)
Oh why oh why not use an enum instead of 4 booleans
"Should be" isn't "Is" -Jay
Message 8 of 12
(3,371 Views)
And how would you translate the four booleans to the 16 enum items? 😄
Message 9 of 12
(3,364 Views)
Boolean array to number.
Or I'm guessing he is suggesting don't use the 4 booleans and instead use an enum. It is hard to say which would be better without knowing more.
Message 10 of 12
(3,361 Views)
