multicolumn listbox column default textsize
I use a multicolumn listbox control to display values queried from a database. There is one column that needs to display more text than the other columns. So i want to set the default text size to a smaller size than the other columns. Up to now I changed the cells text size by clicking each cell individually and adjust the textsize. When i retrieve more records than the number of cells that I have adjusted, the text of the last rows still doesn't fit.
Is there a way to set the default text size per column ? (fe 1 column with text size 14 and the other columns text size 18)
Thanks in advance,
Stef
(2,703 Views)
Hi svh,
why don't you set the text size for the whole column?
Read the help for the "ActiveCell" property of the MCL to know how to select whole column/row/sheet!
(2,681 Views)
try this vi
it help you to select columns and fonts
(2,677 Views)
