multicolumn listbox like excel
Hello everyone.
I'm using the multicolumn listbox.
I want to the multicolumn listbox like excel
I want to the multicolumn listbox each row, column by control
and each graph, each sum etc...
Seek advice.
I appreciate that.
Message 1 of 9
(4,050 Views)
I see you have a multicolumn listbox in your VI.  What is your question?
Where does Excel fit into this?
Message 2 of 9
(4,039 Views)
Want to use the columns and rows of a multi-column list box as Microsoft Excel.
For example, the sum of the daily dose, Number of Rows, Graph of the month dose...
Want to be represented under a multi-column list box.
Best regards.
Message 3 of 9
(4,026 Views)
 A multicolumn listbox is a 2-D array of strings..  Break out the columns you want (Index Array).  Convert the string data to numbers  (String to Number conversion).  Then sum the array (Add Array Elements).
Message 4 of 9
(3,974 Views)
Thank you for your response.
There should not be making reference to.
I counted the number in the first column came out 16.
Not even sum columns.
LabVIEW is very hard for me.
Message 5 of 9
(3,939 Views)
I don't understand your last message.
Are you still having problems?   Attach your latest VI and give a clear explanation of what it is doing wrong.
Message 6 of 9
(3,933 Views)
Thank you for your interest.
I have attached the file.
I just think the multicolumn listbox would like to use as Excel.
Best regards.
Message 7 of 9
(3,907 Views)
Here is how you do what I said earlier to sum those two columns.
Message 8 of 9
(3,893 Views)
Thank you for your help.
In addition, by using a multi-column, I want to draw a graph.
Please check was added to the file.
Your answer will be a great help to me.
Best regard.
Message 9 of 9
(3,876 Views)
